Einleitung
If your Asus TUF gaming FX705G laptop is overheating or overusing its cooling fan, it might be a sign to replace your heatsink. Heatsinks may be damaged for multiple reasons including physical damage, corrosion or oxidization, or compatibility issues.
The heatsinks job is to distribute the heat generated by the laptop while in use. It is normal for the heatsink to be hot to the touch directly after use, especially when it has been used for a long period of time. Make sure to let the laptop sit after use before trying to take it apart.
You will need a #00 Phillips Screwdriver to remove this part.
Was du brauchst
Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
Disconnect the wire from the motherboard, and lift the battery from its housing.
Remove the eight 1.9 mm-long screws securing the heat sink with a Phillips #00 screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
