Zum Hauptinhalt wechseln
Asus TUF Gaming FX705G Keyboard Replacement
Was du brauchst
  1. Asus TUF Gaming FX705G Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Keyboard Replacement, Battery: Schritt 3, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 4, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Keyboard Replacement, Fan: Schritt 5, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement, Fan: Schritt 5, Bild 2 von 2
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 6, Bild 1 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 6, Bild 2 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 7, Bild 1 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 7, Bild 2 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
  8. Asus TUF Gaming FX705G Keyboard Replacement, M.2 SSD: Schritt 8, Bild 1 von 1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  9. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
  10. Asus TUF Gaming FX705G Keyboard Replacement, Speakers: Schritt 10, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement, Speakers: Schritt 10, Bild 2 von 2
    • Use your fingers to lift the speaker from the housing and follow the wire path carefully, lifting the wire out of place around the base.
  11. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 11, Bild 1 von 1
    • Repeat the removal process on the second speaker, being careful not to rip the wire.
  12. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 12, Bild 1 von 1
    • With the second speaker removed from the track, carefully disconnect the three wires from the insert on the motherboard.
  13. Asus TUF Gaming FX705G Keyboard Replacement, Track Pad: Schritt 13, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement, Track Pad: Schritt 13, Bild 2 von 2
    • Take the ribbon wire out of the track pad.
  14. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 14, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  15. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 15, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 15, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  16. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 16, Bild 1 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 16, Bild 2 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 16, Bild 3 von 3
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
  17. Asus TUF Gaming FX705G Keyboard Replacement, Heat Sink: Schritt 17, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement, Heat Sink: Schritt 17, Bild 2 von 2
    • Remove the eight 1.9 mm-long screws securing the heat sink with a Phillips #00 screwdriver.
  18. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 18, Bild 1 von 1
    • Lift the heat sink up and out of the laptop.
  19. Asus TUF Gaming FX705G Keyboard Replacement, Motherboard: Schritt 19, Bild 1 von 3 Asus TUF Gaming FX705G Keyboard Replacement, Motherboard: Schritt 19, Bild 2 von 3 Asus TUF Gaming FX705G Keyboard Replacement, Motherboard: Schritt 19, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove each of the six 1.8 mm-long screws securing the motherboard.
  20. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 20, Bild 1 von 1
    • Use your hands to gently lift up and remove the motherboard.
  21. Asus TUF Gaming FX705G Keyboard Replacement, RAM: Schritt 21, Bild 1 von 1
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
  22. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 22, Bild 1 von 1
    • Pull the RAM directly out of its socket.
  23. Asus TUF Gaming FX705G Keyboard Replacement, Keyboard: Schritt 23, Bild 1 von 1
    • Peel back the flex ribbon cable.
  24. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 24, Bild 1 von 2 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 24, Bild 2 von 2
    • Peel back the film covering the Wi-Fi card.
    • Using your hands, disconnect the Wi-Fi card.
  25. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 25, Bild 1 von 1
    • Peel back the black foam wire covering.
  26. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 26, Bild 1 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 26, Bild 2 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 26, Bild 3 von 3
    • Unscrew the 2.4 mm-long screws with a Phillips #0 screwdriver.
    • Lift the EMI shield plate with your hands and remove it.
    • Using your hands, lift the black film to reveal the foil. Peel back the foil.
  27. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 27, Bild 1 von 1
    • Using a spudger, pop off the plastic rivets around the plate.
  28. Asus TUF Gaming FX705G Keyboard Replacement: Schritt 28, Bild 1 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 28, Bild 2 von 3 Asus TUF Gaming FX705G Keyboard Replacement: Schritt 28, Bild 3 von 3
    • Using a spudger, pop off the plastic rivets around the keyboard.
    • Using your hands, remove the keyboard.
Abschluss
Miranda Kuhn
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 36
Insgesamt: 58
