Zum Hauptinhalt wechseln
Asus TUF Gaming FX705G M.2 SSD Replacement
Was du brauchst
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX705G M.2 SSD Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: Schritt 3, Bild 1 von 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: Schritt 4, Bild 1 von 2 Asus TUF Gaming FX705G M.2 SSD Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: Schritt 5, Bild 1 von 1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: Schritt 6, Bild 1 von 1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 4,009
