Zum Hauptinhalt wechseln
Asus TUF Gaming FX705G Motherboard Replacement
Was du brauchst
    1. Asus TUF Gaming FX705G Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
      • Remove the eleven Phillips #0 screws that secure the back cover.
      Frag FixBot
      Kommentar hinzufügen
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 2, Bild 2 von 2
      • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
      • You will hear pops as the back cover releases.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, RAM: Schritt 3, Bild 1 von 1
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 4, Bild 1 von 1
      • Pull the RAM directly out of its socket.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, Heat Sink: Schritt 5, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement, Heat Sink: Schritt 5, Bild 2 von 2
      • Remove the eight 1.9 mm-long screws securing the heat sink with a Phillips #00 screwdriver.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 6, Bild 1 von 1
      • Lift the heat sink up and out of the laptop.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, Battery: Schritt 7, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement, Battery: Schritt 7, Bild 2 von 2
      • Remove the three Phillips #00 screws from the battery housing.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 8, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 8, Bild 2 von 2
      • Disconnect the wire from the motherboard, and lift the battery from its housing.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, Fan: Schritt 9, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement, Fan: Schritt 9, Bild 2 von 2
      • Remove the five Phillips #00 screws from the fan casings.
      • The left fan has three screws and the right fan has two screws.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 10, Bild 1 von 3 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 10, Bild 2 von 3 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 10, Bild 3 von 3
      • Unplug the cables that connect the fan to the motherboard.
      Frag FixBot
    3. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 11, Bild 1 von 3 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 11, Bild 2 von 3 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 11, Bild 3 von 3
      • Lift the motherboard to unclip the housing clip on the back of the fan.
      • Remove the fan.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, M.2 SSD: Schritt 12, Bild 1 von 1
      • Remove the Phillips #00 screw on the left side of the M.2 SSD.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 13, Bild 1 von 1
      • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, Speakers: Schritt 14, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement, Speakers: Schritt 14, Bild 2 von 2
      • Use your fingers to lift the speaker from the housing and follow the wire path carefully, lifting the wire out of place around the base.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 15, Bild 1 von 1
      • Repeat the removal process on the second speaker, being careful not to rip the wire.
      Frag FixBot
    3. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 16, Bild 1 von 1
      • With the second speaker removed from the track, carefully disconnect the three wires from the insert on the motherboard.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, Track Pad: Schritt 17, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement, Track Pad: Schritt 17, Bild 2 von 2
      • Take the ribbon wire out of the track pad.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 18, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 18, Bild 2 von 2
      • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
      Frag FixBot
    3. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 19, Bild 1 von 2 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 19, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
      Frag FixBot
    4. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 20, Bild 1 von 3 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 20, Bild 2 von 3 Asus TUF Gaming FX705G Motherboard Replacement: Schritt 20, Bild 3 von 3
      • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
      • Slide the track pad up and out of the housing unit.
      Frag FixBot
    1. Asus TUF Gaming FX705G Motherboard Replacement, Motherboard: Schritt 21, Bild 1 von 3 Asus TUF Gaming FX705G Motherboard Replacement, Motherboard: Schritt 21, Bild 2 von 3 Asus TUF Gaming FX705G Motherboard Replacement, Motherboard: Schritt 21, Bild 3 von 3
      • Use a Phillips #0 screwdriver to remove each of the six 1.8 mm-long screws securing the motherboard.
      Frag FixBot
    2. Asus TUF Gaming FX705G Motherboard Replacement: Schritt 22, Bild 1 von 1
      • Use your hands to gently lift up and remove the motherboard.
      Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Patty N
86 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 45
Insgesamt: 302
