Zum Hauptinhalt wechseln
Asus TUF Gaming FX705G RAM Replacement
Was du brauchst
  1. Asus TUF Gaming FX705G RAM Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus TUF Gaming FX705G RAM Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G RAM Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX705G RAM Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G RAM Replacement, Battery: Schritt 3, Bild 1 von 2 Asus TUF Gaming FX705G RAM Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G RAM Replacement: Schritt 4, Bild 1 von 2 Asus TUF Gaming FX705G RAM Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
  6. Asus TUF Gaming FX705G RAM Replacement: Schritt 6, Bild 1 von 1
    • Pull the RAM directly out of its socket.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
LupitaPerez
85 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 61
