Zum Hauptinhalt wechseln
Asus TUF Gaming FX705G Track Pad Replacement
Was du brauchst
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: Schritt 3, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: Schritt 4, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: Schritt 5, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement, Track pad: Schritt 5, Bild 2 von 2
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: Schritt 6, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: Schritt 7, Bild 1 von 2 Asus TUF Gaming FX705G Track Pad Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: Schritt 8, Bild 1 von 3 Asus TUF Gaming FX705G Track Pad Replacement: Schritt 8, Bild 2 von 3 Asus TUF Gaming FX705G Track Pad Replacement: Schritt 8, Bild 3 von 3
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 2,064
