Zum Hauptinhalt wechseln
Asus Transformer Book T100TAF Battery Replacement
Was du brauchst
  1. Asus Transformer Book T100TAF Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Detach the keyboard from the screen by depressing the silver button the hinge and pulling upwards on the tablet.
  2. Asus Transformer Book T100TAF Battery Replacement: Schritt 2, Bild 1 von 1
    • Take the tablet-portion of the device and carefully pry the screen open using either the plastic or metal spudger. Each interior clip needs to be released from the edges.
  3. Asus Transformer Book T100TAF Battery Replacement: Schritt 3, Bild 1 von 2 Asus Transformer Book T100TAF Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the plastic backing from the device and locate the battery pack.
    • Battery pack
  4. Asus Transformer Book T100TAF Battery Replacement: Schritt 4, Bild 1 von 2 Asus Transformer Book T100TAF Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to pry the battery up from the device. Pry from different sides of the battery to loosen and break the glue that is holding it down.
    • The battery cable will release as the battery is removed from the device.
    • Be sure to recycle your old battery.
    • Do not puncture or bend the battery.
Abschluss
To reassemble your device, follow these instructions in reverse order. After replacement, it is advised to calibrate your new battery by fully draining the battery and then charging it, uninterrupted, to 100%.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Elizabeth
565 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 4-3, Passmore Fall 2016 Mitglied von USF Tampa, Team 4-3, Passmore Fall 2016
USFT-PASSMORE-F16S4G3
4 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
Bonjour
Remplacement sans problème pour un ASUS T200TA
Par contre il a perdu le paramétrage du Boot.
Ou puis je retrouver ce parametrage??
jp.boubal - Antwort
Bonjour quelqu’un sait comment retirer la batterie d’origine de l’ordinateur (au niveau de la connection)?
Merci
Pierre-Alain Gallion - Antwort
Hi
What glue did you use to secure the new battery?
Thank you
Paul
Paul - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 51
Letzte 30 Tage: 161
Insgesamt: 15,077
