Einleitung
In order to perform the actions necessary in this guide you will need the tools stated at the top of the guide. Also, while removing the back panel it may be hard to get your tool in exactly the right place to remove the panel. Make sure that the tool is in the right place and be persistent, the panel will come off.
Was du brauchst
Remove the tablet portion of the device from the keyboard by pushing the large silver button near the base of the tablet. Pull up on the tablet to remove from the keyboard.
Insert the iFixit Opening Tool into the seam of the back tablet casing and gently pry upwards. With enough force the clips will release on the back tablet casing.
Move the iFixit Opening Tool along the seam until the entire backing is removed.
