Einleitung
This guide will show you how to replace a faulty USB input by taking apart the keyboard.
Was du brauchst
Remove the tablet portion of the device from the keyboard by pushing on the silver button located at the base of the tablet and lifting up on the tablet.
Remove two 5mm Phillips #0 screws on the top corners.
Remove four 2.5mm Phillips #0 screws on the top corners.
Use the size 0 Phillips screwdriver and remove the nine screws from the back panel. The four you need to remove across the top are 3mm and the four across the bottom are 2.5mm.
The screw in the top right, shown where the screwdriver is, is a 5mm screw.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers and remove the black tape from the back panel.
Flip the connectors back to release the wires
Take the white tab and gently pull it to the right in order to release the connecting piece.
Remove the screw from the green plate.
Once all of the screws are out, remove the plate.
Place soldering tool on each of the four connecting pieces in the corner until each becomes unattached.
Remove old USB input and replace with the new one.
