Zum Hauptinhalt wechseln
Einleitung
Are you experiencing issues powering on your flip book? Is it losing it's charge very quickly? If so, this guide will help you replace a faulty battery in a few easy steps.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Asus Transformer Flip Book TP200S Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Transformer Flip Book TP200S Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S Battery Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S Battery Replacement: Schritt 4, Bild 1 von 2 Asus Transformer Flip Book TP200S Battery Replacement: Schritt 4, Bild 2 von 2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alejandro Lopez
662 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Mitglieder
3 Kommentare
how if my laptop not charge but the battery have replace before
Chen _El - Antwort
its tooeasy! Thank You!
fotonngn - Antwort
Its too easy! Tnks!
fotonngn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 9
Letzten 30 Tage: 36
Insgesamt: 2,525
