Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Are you experiencing issues powering on your flip book? Is it losing it's charge very quickly? If so, this guide will help you replace a faulty battery in a few easy steps.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back 6mm and 8mm screws with a J000 screwdriver. Remove the back 6mm and 8mm screws with a J000 screwdriver.
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Remove the back cover of the flip book by gently using a metal spudger. Remove the back cover of the flip book by gently using a metal spudger.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  5. The battery comes attached to the motherboard and needs to be disconnected before you can remove it. Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Abschluss
Alejandro Lopez
635 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Mitglieder
how if my laptop not charge but the battery have replace before
Chen _El - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 37
Insgesamt: 953
