Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If your screen is damaged or unresponsive then a replacement may be in order. Follow this guide to do it yourself in a few easy steps.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back 6mm and 8mm screws with a J000 screwdriver. Remove the back 6mm and 8mm screws with a J000 screwdriver.
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Remove the back cover of the flip book by gently using a metal spudger. Remove the back cover of the flip book by gently using a metal spudger.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. The battery comes attached to the motherboard and needs to be disconnected before you can remove it. Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
  6. Open your flip book so that the screen faces towards you. You will notice 2 rubber pads at the base of the screen. Using a metal spudger, lift the rubber pads off to find 2 screen 3mm screws. Unscrew these 3mm screw with a phillips head J000 screwdriver.
    • Open your flip book so that the screen faces towards you. You will notice 2 rubber pads at the base of the screen.
    • Using a metal spudger, lift the rubber pads off to find 2 screen 3mm screws. Unscrew these 3mm screw with a phillips head J000 screwdriver.
  7. After removing the screws, use the metal spudger to gentle pry open the screen casing from the flip book casing. After removing the screws, use the metal spudger to gentle pry open the screen casing from the flip book casing.
    • After removing the screws, use the metal spudger to gentle pry open the screen casing from the flip book casing.
  8. Gently remove all the connections and tape you see attached to the screen with tweezers. Gently remove all the connections and tape you see attached to the screen with tweezers.
    • Gently remove all the connections and tape you see attached to the screen with tweezers.
  9. After all connections have been removed, use the metal spudger and pry the screen itself from the screen casing.
    • After all connections have been removed, use the metal spudger and pry the screen itself from the screen casing.
    • Caution: The screen is glued to the screen casing with adhesive so you will need to exert some force to get the screen off. This will likely damage your old screen permanently. Be certain you have a replacement readily available before you engage in this step.
    • You will not need to reapply the adhesive.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Alejandro Lopez
635 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 8
Letzten 30 Tage: 23
Insgesamt: 878
