Einleitung
Are you unable to connect to any WiFi connection? If so, then you might be experiencing a faulty WiFi card. This guide will take you through all the steps required to replace your Asus Flip Book WiFi card.
Was du brauchst
Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
