Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Are you unable to connect to any WiFi connection? If so, then you might be experiencing a faulty WiFi card. This guide will take you through all the steps required to replace your Asus Flip Book WiFi card.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back 6mm and 8mm screws with a J000 screwdriver. Remove the back 6mm and 8mm screws with a J000 screwdriver.
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Remove the back cover of the flip book by gently using a metal spudger. Remove the back cover of the flip book by gently using a metal spudger.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. The battery comes attached to the motherboard and needs to be disconnected before you can remove it. Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
  5. The WiFi card will be covered by tape and attached to the motherboard.
    • The WiFi card will be covered by tape and attached to the motherboard.
    • Remove the tape from the WiFi card.
  6. Unscrew the WiFi card with a JIS #000 screwdriver. Remove the motherboard connection from the WiFi card with tweezers. Pull out the WiFi card.
    • Unscrew the WiFi card with a JIS #000 screwdriver.
    • Remove the motherboard connection from the WiFi card with tweezers.
    • Pull out the WiFi card.
Abschluss
Alejandro Lopez
635 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 6
Letzten 30 Tage: 11
Insgesamt: 228
