Zum Hauptinhalt wechseln
Asus Transformer Pad Infinity Glass Replacement
Was du brauchst
  1. Asus Transformer Pad Infinity Glass Replacement, Glass: Schritt 1, Bild 1 von 3 Asus Transformer Pad Infinity Glass Replacement, Glass: Schritt 1, Bild 2 von 3 Asus Transformer Pad Infinity Glass Replacement, Glass: Schritt 1, Bild 3 von 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity Glass Replacement: Schritt 2, Bild 1 von 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity Glass Replacement: Schritt 3, Bild 1 von 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity Glass Replacement: Schritt 4, Bild 1 von 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity Glass Replacement: Schritt 5, Bild 1 von 1
    • Once removed, replace the glass screen back onto the LCD display.
    • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Allison Poh
549 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 816
