Zum Hauptinhalt wechseln
Asus Transformer Pad TF103C Speakers Replacement
Was du brauchst
  1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: Schritt 1, Bild 1 von 1
    • Shut down your tablet before beginning the repair.
    • Insert the plastic opening tool on the side of the tablet.
    • Gently pull upwards and carefully pry open the tablet.
  2. Asus Transformer Pad TF103C Speakers Replacement: Schritt 2, Bild 1 von 1
    • Slide the tool around all four sides of the tablet while gently pulling the tool up.
  3. Asus Transformer Pad TF103C Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
    • Rotate the tablet to match the picture.
  4. Asus Transformer Pad TF103C Speakers Replacement: Schritt 4, Bild 1 von 1
    • Carefully unplug the rainbow cable from the motherboard.
  5. Asus Transformer Pad TF103C Speakers Replacement: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool to carefully pry the battery out from the frame.
  6. Asus Transformer Pad TF103C Speakers Replacement: Schritt 6, Bild 1 von 2 Asus Transformer Pad TF103C Speakers Replacement: Schritt 6, Bild 2 von 2
    • Use the JIS #000 screwdriver to remove the four screws.
    • Keep the screws together and organized. (Label the screws, if necessary).
  7. Asus Transformer Pad TF103C Speakers Replacement: Schritt 7, Bild 1 von 1
    • Take the ground wire out from the top of the TF103C-L (left) speaker.
    • If you pull on the wire too much it will break off.
    • If you break the wire off you can solder it back on.
  8. Asus Transformer Pad TF103C Speakers Replacement: Schritt 8, Bild 1 von 1
    • Remove the tape and unplug the wire that is connected to both of the speakers.
  9. Asus Transformer Pad TF103C Speakers Replacement: Schritt 9, Bild 1 von 2 Asus Transformer Pad TF103C Speakers Replacement: Schritt 9, Bild 2 von 2
    • Remove the two speakers from the frame.
Abschluss
Tyler Ellis
668 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Mitglied von UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 470
