Einleitung
All the buttons on the tablet are located in one corner. They are all controlled by a button module board, which can be removed if desired.
Was du brauchst
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
Insert the opening tool into the seam of the tablet casing and gently pry upwards.
With a little force, you will feel the clips release.
Slide the tool along all four edges of the tablet, making sure that all the clips are released.
Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
Remove the screws using a Phillips Head #1 screwdriver.
Remove the power button module.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
