Einleitung
Use this guide to replace the front-facing camera board on your Asus Transformer T100.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
Insert the opening tool into the seam of the tablet casing and gently pry upwards.
With a little force, you will feel the clips release.
Slide the tool along all four edges of the tablet, making sure that all the clips are released.
The camera board is located in the red square in this image.
Lift up the power button cable retention clip on the motherboard and pull the cable out.
On the camera connection apparatus, locate the silver tape that connects to the tablet.
Peel the silver tape off of the tablet on both sides of the connection apparatus.
2 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
