Zum Hauptinhalt wechseln
Asus U47VC-DS51 Cooling Fan Replacement
Was du brauchst
  1. Asus U47VC-DS51 Cooling Fan Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Asus U47VC-DS51 Cooling Fan Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Asus U47VC-DS51 Cooling Fan Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Remove the hard drive cover.
    • Unscrew one 8mm Phillips #00 screw.
    • Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
  2. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 2, Bild 1 von 3 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 2, Bild 2 von 3 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • Remove the hard drive.
    • Unscrew the four 3mm Phillips #00 screws.
    • Pull the hard drive's black tab away from the laptop to free it.
  3. Asus U47VC-DS51 Cooling Fan Replacement, Keyboard: Schritt 3, Bild 1 von 2 Asus U47VC-DS51 Cooling Fan Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
    • Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
  4. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Using the black spudger, insert its flat end between the crevice where the color changes from grey to black.
    • The keyboard is very tightly secured.
    • Carefully ease the spudger's end along the crevice, going around the entire frame.
    • The back connectors are short, so be careful when lifting.
  5. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 5, Bild 1 von 2 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Lift the keyboard from the front where it is closest to the screen.
    • Disconnect the large and small ZIF connectors attached to the motherboard by flipping the light-colored part of the switch.
  6. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 6, Bild 1 von 2 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 6, Bild 2 von 2
    • Remove the third and last ZIF connector on the motherboard by flipping up the dark-colored part of the switch.
    • Now, the component should come completely free.
  7. Asus U47VC-DS51 Cooling Fan Replacement, Motherboard: Schritt 7, Bild 1 von 3 Asus U47VC-DS51 Cooling Fan Replacement, Motherboard: Schritt 7, Bild 2 von 3 Asus U47VC-DS51 Cooling Fan Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Unscrew the one 8mm screw using a Phillips #00.
    • Using the black spudger, slightly pry up on the tab and gently pull the optical drive away from the laptop in order to remove it.
  8. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 8, Bild 1 von 3 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 8, Bild 2 von 3 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 8, Bild 3 von 3
    • Using the black spudger, slowly lift up on the cable connectors and pull them away from the connectors.
    • Repeat steps on both cables.
    • Unscrew the 12 8mm screws using a Phillips #00 screwdriver.
  9. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 9, Bild 1 von 3 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 9, Bild 2 von 3 Asus U47VC-DS51 Cooling Fan Replacement: Schritt 9, Bild 3 von 3
    • Lift up on the motherboard and disengage the two connectors.
    • Disconnect the cooling fan connector.
    • Unscrew the 7 8mm screws holding in the cooling fan using a Phillips #00 screwdriver.
  10. Asus U47VC-DS51 Cooling Fan Replacement, Cooling fan: Schritt 10, Bild 1 von 3 Asus U47VC-DS51 Cooling Fan Replacement, Cooling fan: Schritt 10, Bild 2 von 3 Asus U47VC-DS51 Cooling Fan Replacement, Cooling fan: Schritt 10, Bild 3 von 3
    • Use a Phillips screwdriver to loosen the four screws holding the component in place.
  11. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 11, Bild 1 von 1
    • After loosening the screws, use the black spudger to help disconnect the fan wires from the connector.
  12. Asus U47VC-DS51 Cooling Fan Replacement: Schritt 12, Bild 1 von 1
    • The fan should then come free.
Abschluss
Devontae Williams
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 541
