Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
We will teach you how to remove/replace the Optical Drive of your Asus U50F-RBBAG05.
  1. Turn the laptop over so the bottom is facing up.
    • Turn the laptop over so the bottom is facing up.
    • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
    • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
    • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
  2. Hold down the tab on the right side, then begin sliding the battery out. Remove the old battery.
    • Hold down the tab on the right side, then begin sliding the battery out.
    • Remove the old battery.
    • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
  3. Remove 6 screws
    • Remove 6 screws
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. Pry the lower panel up with your fingernail/spudger.
    • Pry the lower panel up with your fingernail/spudger.
  6. Lift up and remove Lift up and remove
    • Lift up and remove
  7. Remove 1 screw
    • Remove 1 screw
  8. Use the plastic opening tool to push the drive out from the back.
    • Use the plastic opening tool to push the drive out from the back.
  9. Pull drive out and remove completely. Tip: When reassembling the drive, put the laptop right-side-up.  Then, push the drive all the way in.  Finally, flip back over and continue with the directions. (Otherwise the drive will catch and be difficult to reassemble)
    • Pull drive out and remove completely.
    • Tip: When reassembling the drive, put the laptop right-side-up. Then, push the drive all the way in. Finally, flip back over and continue with the directions. (Otherwise the drive will catch and be difficult to reassemble)
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 65
