Zum Hauptinhalt wechseln
Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement
Was du brauchst
  1. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over so the bottom is facing up.
    • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
    • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
    • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
  2. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 2, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 2, Bild 2 von 2
    • Hold down the tab on the right side, then begin sliding the battery out.
    • Remove the old battery.
    • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
  3. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Underpanel: Schritt 3, Bild 1 von 1
    • Remove the six screws using a Phillips #1 screwdriver.
  4. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 4, Bild 1 von 1
    • Pry the lower panel up with your fingernail or a spudger.
  5. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 5, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 5, Bild 2 von 2
    • Lift up on the panel and remove it.
  6. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Remove the two screws using a Phillips #1 screwdriver.
  7. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 7, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 7, Bild 2 von 2
    • Using your finger, push the hard drive back.
    • Pry up the drive with an opening tool (or your fingernail).
  8. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 8, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 8, Bild 2 von 2
    • Pull back on the hard drive and lift upwards.
    • Remove the component completely.
  9. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Optical Drive: Schritt 9, Bild 1 von 1
    • Remove the single screw.
  10. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to push the drive out from the back.
  11. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 11, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 11, Bild 2 von 2
    • Pull the drive out and remove completely.
    • When reassembling the drive, lay the laptop with the base towards the floor. Then, push the drive all the way in. Otherwise, the drive will become stuck and be difficult to reassemble.
  12. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Keyboard: Schritt 12, Bild 1 von 3 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Keyboard: Schritt 12, Bild 2 von 3 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Keyboard: Schritt 12, Bild 3 von 3
    • Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
    • Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
    • Repeat the same process all the way down to the opposite corner.
  13. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 13, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 13, Bild 2 von 2
    • Once the keyboard is free, lift it up slightly and release the cable connection underneath.
  14. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 14, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 14, Bild 2 von 2
    • Last, remove the keyboard completely from the computer.
  15. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Random Access Memory (RAM): Schritt 15, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Random Access Memory (RAM): Schritt 15, Bild 2 von 2
    • Push back on the silver clips shown in the picture until you hear/feel a pop.
  16. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 16, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 16, Bild 2 von 2
    • Pull back on the RAM card and remove it.
    • Repeat for the lower RAM card.
  17. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Upper Case: Schritt 17, Bild 1 von 3 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Upper Case: Schritt 17, Bild 2 von 3 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Upper Case: Schritt 17, Bild 3 von 3
    • Remove the six screws from the outer lower case.
    • Remove the four screws from the hinges.
    • Remove the three screws on the inner lower case.
    • Remove the three screws from the optical drive area.
  18. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 18, Bild 1 von 2 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 18, Bild 2 von 2
    • Remove the two screws from the metal frame.
  19. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 19, Bild 1 von 3 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 19, Bild 2 von 3 Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 19, Bild 3 von 3
    • Pull the two bundled cables away from the connector in the same direction as the individual wires are running.
    • Potential for device damage: Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Pull the no-fuss ribbon cable straight out of the connector.
    • Potential for device damage: These kinds of connectors are fairly rare, so check carefully for a way to release the connector before you resort to pulling on the ribbon cable.
    • Pull the single bundled cable away from the connector in the same direction as the individual wires are running.
  20. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 20, Bild 1 von 1
    • Lift up and remove the upper case.
  21. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement, Ports (USB/Audio Jack/Microphone Jack/E-SATA): Schritt 21, Bild 1 von 1
  22. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 22, Bild 1 von 1
    • Pull the cable away from the connector in the same direction as the individual wires.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  23. Asus U50F-RBBAG05 Ports (USB/Audio Jack/Microphone Jack/E-SATA) Replacement: Schritt 23, Bild 1 von 1
    • Lift up and remove the port panel.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 232
