Zum Hauptinhalt wechseln
Asus U56E Laptop Screen Replacement
Was du brauchst
  1. Asus U56E Laptop Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Asus U56E Laptop Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Position the laptop on a flat, stable surface, with the underside facing upward.
  2. Asus U56E Laptop Screen Replacement: Schritt 2, Bild 1 von 3 Asus U56E Laptop Screen Replacement: Schritt 2, Bild 2 von 3 Asus U56E Laptop Screen Replacement: Schritt 2, Bild 3 von 3
    • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
    • Slide the two battery lock switches toward each other.
    • Lift the battery to remove it from the laptop.
  3. Asus U56E Laptop Screen Replacement: Schritt 3, Bild 1 von 3 Asus U56E Laptop Screen Replacement: Schritt 3, Bild 2 von 3 Asus U56E Laptop Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
    • Lift the cover, exposing the laptop hard drive and RAM.
  4. Asus U56E Laptop Screen Replacement: Schritt 4, Bild 1 von 2 Asus U56E Laptop Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the eight small screws holding the hard drive in.
    • The hard drive cover can now be removed by lifting the tab on the left.
  5. Asus U56E Laptop Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
  6. Asus U56E Laptop Screen Replacement: Schritt 6, Bild 1 von 2 Asus U56E Laptop Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the 4 Phillips #00 screws around the RAM.
  7. Asus U56E Laptop Screen Replacement: Schritt 7, Bild 1 von 2 Asus U56E Laptop Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove the 10 Phillips #00 screws from the bottom of the laptop.
    • Remove 10 Phillips #000 screws from under the battery.
  8. Asus U56E Laptop Screen Replacement: Schritt 8, Bild 1 von 2 Asus U56E Laptop Screen Replacement: Schritt 8, Bild 2 von 2
    • Slide the optical drive out of the laptop.
    • Gently lift the rear plastic hinge cover to separate it from the laptop.
  9. Asus U56E Laptop Screen Replacement: Schritt 9, Bild 1 von 3 Asus U56E Laptop Screen Replacement: Schritt 9, Bild 2 von 3 Asus U56E Laptop Screen Replacement: Schritt 9, Bild 3 von 3
    • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
    • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
    • Be aware of the thin cables still connected to the screen.
  10. Asus U56E Laptop Screen Replacement: Schritt 10, Bild 1 von 2 Asus U56E Laptop Screen Replacement: Schritt 10, Bild 2 von 2
    • Gently lift around the perimeter of keyboard to separate it from the laptop body.
    • It may help to use a Plastic Opening Tool.
    • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
  11. Asus U56E Laptop Screen Replacement: Schritt 11, Bild 1 von 3 Asus U56E Laptop Screen Replacement: Schritt 11, Bild 2 von 3 Asus U56E Laptop Screen Replacement: Schritt 11, Bild 3 von 3
    • Pull the display connector straight up to remove it from the motherboard.
    • Carefully detach the white and black WiFi antennas from the wireless adapter.
  12. Asus U56E Laptop Screen Replacement: Schritt 12, Bild 1 von 1
    • The screen can now be safely removed from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
David Zilar
167 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-5, Green Fall 2015 Mitglied von Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,341
