Einleitung
This guide outlines how to replace a keyboard on an Asus budget laptop. These laptops are quite compact, which results in a keyboard replacement being a very involved process.
Was du brauchst
Locate the battery locking tabs on the upper right and left corner.
Press the tabs in towards each other.
Use a plastic opening tool around the entire edge.
Separate the case from the keyboard.
Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
2 Kommentare
I removed the Keyboard from the Top Case and replaced the Keyboard. It wasn’t too bad with my Heat Gun and all-in-one painters tool…yes you heard right, my handy dandy painters tool that has served me well for years. Anyway, the only problem area taking the Keyboard out and snapping it back in (if you want to call it that) was by the DVD Player. Good Luck!
