Zum Hauptinhalt wechseln
Asus UL30VT-X1 Battery Replacement
Was du brauchst
  1. Asus UL30VT-X1 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Asus UL30VT-X1 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over onto the back. (Second Image)
  2. Asus UL30VT-X1 Battery Replacement: Schritt 2, Bild 1 von 2 Asus UL30VT-X1 Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate the two battery locks. (First Image)
    • The battery lock on the left will need to be unlocked first which is done by pushing the lock to the left. (Second Image)
    • A red line should show which indicates it is unlocked.
  3. Asus UL30VT-X1 Battery Replacement: Schritt 3, Bild 1 von 1
    • Unlock the right lock by moving it to the right while simultaneously pushing upwards on the battery.
    • The battery should slide out of place.
Abschluss
Robert Wilcox
218 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 297
