Einleitung
This guide will show the steps to take out and replace a defective hard drive for the Asus UL30VT-X1.
Was du brauchst
Unscrew the three screws on the hard drive panel using a Phillips Head #00 screwdriver.
Lift the hard drive panel up from the small cut out at the bottom with your finger to expose the hard drive.
Grab the black pull tab with your fingers. Pull upwards and then outwards to remove the hard drive.
Fast fertig!
Abschluss
