Einleitung
Replacing the battery is very straightforward. Once the battery is unlocked, it will come right out. This replacement can be done when battery life is poor or if the battery is not holding a charge at all.
Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
Eine weitere Person hat diese Anleitung absolviert.
