Einleitung
The keyboard is the appliance used to input your laptop with data, text, and commands. If input is unresponsive. The keyboard will need to be replaced. This guide will walk you through the process.
Was du brauchst
Open laptop so the keyboard is accessible.
Insert a plastic prying tool and push and then pull to release the keyboard from the device.
Lift keyboard and remove ZIF connector cables.
Remove the keyboard from the device.
2 weitere Personen haben diese Anleitung absolviert.
