Einleitung
In this guide, you will learn how to replace the battery in the Asus V500CA-DB51T. This guide was made to help with replacing a broken, defective, or old battery, and is an easy repair for any skill level.
Was du brauchst
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case.
Remove the lower case and set it aside.
Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
Remove the tri-point screws that secure the battery to the casing.
All screws securing the battery in place are .5 cm tri-point screws.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
