Einleitung
Replacing a CD/DVD drive may need to take place when the drive simply fails to perform its normal functions. It has built up too much debris/dust, or the drive itself may have no power due to broken internal mechanisms and parts. Replacing the drive may resolve issues with lag and lack of smooth audio/visuals so the CD/DVD can run smoothly for anyone wanting to enjoy media, or burn a CD.
Before beginning, unplug the laptop and make sure it is completely off.
The battery and hard drive will need to be removed before replacing the CD/DVD drive on the last step.
Was du brauchst
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
Insert a spudger into the hole to carefully push the CD/DVD drive out.
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
