Einleitung
Like any laptop, the display of the Asus V6800V laptop can be damaged by being struck or dropped. Utilize this guide to remove a damaged display in order to replace it with a new one.
Before replacing the display, ensure that a loss of video isn’t caused by another issue.
Be sure to remove the charger and battery from the computer before beginning.
Was du brauchst
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
Remove the internal cables from front to back.
Use your fingers to gently remove the cables from their sockets.
After separating the top and bottom halves of the case, lay them flat on the work area.
Remove the six screws (three on each side) holding the top panel of the chassis to the display with a Phillips #0 screwdriver.
Remove the display by leaving the display flat on the table and tilting the panel up (as if opening the laptop). This will shift the hinges to allow easy removal.
Separate the chassis from the display. If the screws were removed properly, it should come free.
Remove six screws from underneath the bezel with a Phillips #0 screwdriver. Two are located next to each hinge and one at each top corner.
Look behind the display. Locate the display connector.
Peel back the tape from over the connector.
Remove the connector from the display and slowly pull the cable away, peeling the tape back along the way.
Eine weitere Person hat diese Anleitung absolviert.
