Zum Hauptinhalt wechseln
Asus V6800V Fan Replacement
Was du brauchst
  1. Asus V6800V Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Asus V6800V Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: Schritt 2, Bild 1 von 2 Asus V6800V Fan Replacement, Fan: Schritt 2, Bild 2 von 2
    • Use the Phillips #0 to remove the six screws on the back of the device.
    • Gently open the cover using the tab located by the highlighted box.
  3. Asus V6800V Fan Replacement: Schritt 3, Bild 1 von 2 Asus V6800V Fan Replacement: Schritt 3, Bild 2 von 2
    • Unplug the wires by pulling straight up on the white connector and away from the computer.
    • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: Schritt 4, Bild 1 von 2 Asus V6800V Fan Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 to remove the three screws holding the fan in place.
  5. Asus V6800V Fan Replacement: Schritt 5, Bild 1 von 2 Asus V6800V Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove the fan from the device.
    • The fan should remove easily.
  6. Asus V6800V Fan Replacement: Schritt 6, Bild 1 von 2 Asus V6800V Fan Replacement: Schritt 6, Bild 2 von 2
    • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
Abschluss
Jong Park
114 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-9, Johann Summer 2010 Mitglied von Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 5,183
