Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Flip the computer over so that it is upside down.
Slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Locate the little tabs above the INSERT, F10 and F1 keys, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Pull the keyboard out at a 45 degree angle and place it upside down on the scroll pad.
Pull the wide ribbon cable laterally from its socket on the motherboard.
