Einleitung
Use this guide to open the lower case of the Asus V6800V.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Flip the computer over so that it is upside down.
Slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Locate the little tabs above the INSERT, F10 and F1 keys, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Pull the keyboard out at a 45 degree angle and place it upside down on the scroll pad.
Pull the wide ribbon cable laterally from its socket on the motherboard.
Unscrew the screws at the bottom of the chassis to remove the top panel.
The case needs to be separated. Use your fingers or a pry tool to gently start at the front and work around the entire case.
Remove the internal cables by starting with those in the front and working towards the back.
Use your fingers to gently remove the cables from their sockets.
Once you can separate the screen and top case from the bottom case, lay them flat so you can work on the computer more easily.
