Zum Hauptinhalt wechseln
Asus VivoBook E203MA-TBCL432B Power Button Replacement
Was du brauchst
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 2, Bild 1 von 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 2, Bild 2 von 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 3, Bild 1 von 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 3, Bild 2 von 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 3, Bild 3 von 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: Schritt 4, Bild 1 von 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: Schritt 4, Bild 2 von 2
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 5, Bild 1 von 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: Schritt 6, Bild 1 von 1
    • Now that the power button component is free, lift it up and out of the laptop.
Abschluss
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G1, Bailey Spring 2019
UMASSD-BAILEY-S19S8G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 895
