Einleitung
This guide shows how to remove or replace the battery of your Vivo FlipBook 14
Was du brauchst
Unplug the laptop, power it off, and turn it over.
Remove the four long screws, marked in red, and place them aside.
Remove the six shorter screws, marked in orange, and place them aside as well.
Starting from the power button area, insert a flat pry tool between the side and back of the laptop, and lever the back away from the rest of the case.
Continue around the rear (hinge side) of the laptop, ensuring that you insert the tool at the proper seam.
Once the sides and rear clips are pried free, the back can be gently swung away to unclip the front of the back.
Our focus is on the battery connector, highlighted in green. The connector plugs in perpendicular to the motherboard - straight up and down, rather than sliding to one side.
Using a plastic spudger, slide the metal retaining clip away from battery, about 2 or 3mm.
Then, using a spudger under either side, lift the white plastic battery connector up and away from the motherboard.
Remove the four screws holding down the battery, and lift it from the laptop case.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
