Einleitung
This guide helps you replace the hard disk drive (HDD) in your Asus VivoBook Flip 14 TP410U.
Was du brauchst
Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
Use a metal or nylon spudger to pry open the back cover on all sides.
Remove the back cover to access the inside where the hard disk drive is located.
Locate the hard-drive.
Disconnect the hard disk drive from its connectors, and remove the drive.
Eine weitere Person hat diese Anleitung absolviert.
