Zum Hauptinhalt wechseln
Asus VivoBook Q200E-BHI3T45 Fan Replacement
Was du brauchst
  1. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Asus VivoBook Q200E-BHI3T45 Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 3, Bild 1 von 2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 4, Bild 1 von 2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Fan: Schritt 6, Bild 1 von 1
    • Gently peel off the tape from the fan.
  7. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 7, Bild 1 von 2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 7, Bild 2 von 2
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 9, Bild 1 von 2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: Schritt 9, Bild 2 von 2
    • Grab the sides of the fan assembly and remove it by lifting upwards.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Bryann Tan
877 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 16-2, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 580
