Einleitung
This guide will show you how to remove the fan for replacement or cleaning.
Was du brauchst
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
Remove five 5mm screws using a Phillips 0 screwdriver.
Remove the two 2mm screws with a Phillips 000 screwdriver.
Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
