Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will show you how to locate and replace the display if experiencing display issues.
  1. First open the laptop and place it so that you have access to the side of the display. Next you want to place the laptop in a position where you have easy access to the display.
    • First open the laptop and place it so that you have access to the side of the display.
    • Next you want to place the laptop in a position where you have easy access to the display.
    • Use a metal or a plastic prying tool to split the front and back of the display.
    • Start on the side and work your way around.
  2. Pull the clear plastic display down from the bottom right and left. If pulled from the top you might crack the actual plastic.
    • Pull the clear plastic display down from the bottom right and left.
    • If pulled from the top you might crack the actual plastic.
  3. Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
    • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
    • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
  6. Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
    • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
  7. Here is a picture of the connection that needs to be removed to free the display.
    • Here is a picture of the connection that needs to be removed to free the display.
    • Pull connection from the plastic on the sides not the wires as these are fragile.
  8. Once this connection is removed here's what that should look. Once this connection is removed here's what that should look.
    • Once this connection is removed here's what that should look.
  9. Remove display and place your new one in it's place.
    • Remove display and place your new one in it's place.
Abschluss
Mitchell Jackson
742 Reputation
7 Anleitungen geschrieben
IUPUI, Team S4-G4, Wilson Summer 2017 Mitglied von IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Mitglieder
You are suppose to remove the hinge/screen assembly from the laptop chasis before starting step 1, if you don't you will break the digitizer author please fix the guide
Nicholas Chan - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 22
Insgesamt: 1,235
