Einleitung
This guide will show you how to remove and replace the keyboard if experiencing issues.
Was du brauchst
Turn off the computer and unplug the charge cable.
Turn the computer upside down.
Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
Next, carefully lift the LAN bracket out of the slot.
Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
Locate and unplug the power bus from the motherboard.
The motherboard can now be replaced.
Remove the eight 4.7mm Philips #00 screws holding the battery in place.
The battery is attached by a set of wires.
Use your finger to disconnect the set of wires. It should come off very easily.
Remove all of the metallic tape holding the metal bracket to the components surrounding it.
Unscrew the four 3.5mm screws with Phillips #00 Head.
This black plastic panel holds the trackpad in place.
Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
Next, unscrew the two 4.9mm hinge screws with a Phillips #00 screwdriver.
Remove the ten 4.9mm screws holding the metal keyboard panel in place, using a Phillips #00 screwdriver.
Carefully lift the metal keyboard panel out of the slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
