Einleitung
This guide will show you how to remove and replace the trackpad. The trackpad is located inside the back panel and is fairly easy to replace if you are experiencing touch issues with the trackpad.
Was du brauchst
Turn off the computer and unplug the charge cable.
Turn the computer upside down.
Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
Remove the eight 4.7mm Philips #00 screws holding the battery in place.
The battery is attached by a set of wires.
Use your finger to disconnect the set of wires. It should come off very easily.
Remove all of the metallic tape holding the metal bracket to the components surrounding it.
Unscrew the four 3.5mm screws with Phillips #00 Head.
This black plastic panel holds the trackpad in place.
