Zum Hauptinhalt wechseln
Asus VivoBook Q200E-BSI3T08 Webcam Replacement
Was du brauchst
  1. Asus VivoBook Q200E-BSI3T08 Webcam Replacement, Display: Schritt 1, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Webcam Replacement, Display: Schritt 1, Bild 2 von 2
    • First open the laptop and place it so that you have access to the side of the display.
    • Next you want to place the laptop in a position where you have easy access to the display.
    • Use a metal or a plastic prying tool to split the front and back of the display.
    • Start on the side and work your way around.
  2. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 2, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 2, Bild 2 von 2
    • Pull the clear plastic display down from the bottom right and left.
    • If pulled from the top you might crack the actual plastic.
  3. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
  4. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 5, Bild 1 von 1
    • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
  6. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 6, Bild 1 von 1
    • Here is a picture of the connection that needs to be removed to free the display.
    • Pull connection from the plastic on the sides not the wires as these are fragile.
  7. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 7, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 7, Bild 2 von 2
    • Once this connection is removed here's what that should look.
  8. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 8, Bild 1 von 1
    • Remove display and place your new one in it's place.
  9. Asus VivoBook Q200E-BSI3T08 Webcam Replacement, Webcam: Schritt 9, Bild 1 von 1
    • Locate the webcam above and behind the display panel.
  10. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the webcam from the display panel, using a nylon spudger.
    • Using a metal spudger around sensitive components has the potential to damage them. Be sure to use a nylon spudger or plastic opening tool before using a metal spudger.
  11. Asus VivoBook Q200E-BSI3T08 Webcam Replacement: Schritt 11, Bild 1 von 1
    • Remove the webcam from the display panel.
Abschluss
IUPUI, Team S4-G4, Wilson Summer 2017 Mitglied von IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 991
