Zum Hauptinhalt wechseln
Asus VivoBook Q302LA-BHI3T09 Display Replacement
Was du brauchst
  1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: Schritt 1, Bild 1 von 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 2, Bild 1 von 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 2, Bild 2 von 2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 3, Bild 1 von 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 3, Bild 2 von 2
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 4, Bild 1 von 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 4, Bild 2 von 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 4, Bild 3 von 3
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 5, Bild 1 von 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the white and black wires attached to the Wi-Fi chip.
  6. Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 6, Bild 1 von 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 6, Bild 2 von 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 6, Bild 3 von 3
    • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  7. Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 7, Bild 1 von 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 7, Bild 2 von 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: Schritt 7, Bild 3 von 3
    • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
Abschluss
Deric Wright
636 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S5-G5, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 253
