Einleitung
The Printed Circuit Board is a foundation to the majority of electronic devices that serves a purpose to sync all mechanical aspects of a device. Printed Circuit Boards could fail due to several things such as physical damage, component failure, trace damage, poor design, and power failure. Typically the reason of failure will need a clear, professional diagnosis; however, if any electrical component (such as lights or the tracking pad) of your ASUS VivoBook S200e-RHI3T73 isn’t functioning properly, and you want to try your hand at replacing the entire PCB yourself, follow this guide to replace the board.
Before using this guide, I suggest getting your device looked over my a professional who can accurately diagnose the problem as there might be a simpler fix. Sometimes the PCB just needs to be cleaned, or certain wires may need to be reconnected. If said professional suggests replacing the entire board, continue with our easy, less-than-thirty-minute guide to solve your tech problem today.
Be sure to unplug and power off your device completely before beginning your replacement.
Use caution throughout the processes of this guide. Elements of the ASUS VivoBook S200e-RHI3T73 are fragile and easy to bend if not handled with delicacy—which may prevent your device from returning to its original, functioning state.
Was du brauchst
Use a metal spudger to pry the bottom panel open.
Lift the back panel to expose the inside of the laptop.
Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
Using a set of precision tweezers, lift the motherboard connector tab.
Use a nylon spudger or your fingers to gently pry the battery up.
Remove the battery.
Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
Gently remove back panel
Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
Peel the protective wire tape off of the multicolored wires.
Use the precision tweezers to disconnect the wires and gently remove the fan.
Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
Remove the PCB board.
Eine weitere Person hat diese Anleitung absolviert.
