Einleitung
Replace your unresponsive screen to return display to your VivoBook.
Was du brauchst
With the screen closed, place your laptop upside-down with the front facing you.
Remove the five black 80mm Phillips #0 screws.
Remove the four black 50mm Phillips #0 screws.
Use a metal spudger to pry the bottom panel open.
Lift the back panel to expose the inside of the laptop.
Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
4 weitere Personen haben diese Anleitung absolviert.
