Zum Hauptinhalt wechseln
Asus VivoBook X202E-DB21T Battery Replacement
Was du brauchst
  1. Asus VivoBook X202E-DB21T Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Asus VivoBook X202E-DB21T Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Battery Replacement: Schritt 2, Bild 1 von 2 Asus VivoBook X202E-DB21T Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Battery Replacement: Schritt 3, Bild 1 von 2 Asus VivoBook X202E-DB21T Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Battery Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 18
Insgesamt: 374
