Einleitung
The power port is where the power cable plugs into to send power to the battery and the motherboard. If this port is damaged, it may be impossible to charge the battery or power the computer. Replacing this component must be done with care, as any loose or crossed connections may result in device failure.
Was du brauchst
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
Remove the single 3mm screw from the sound chip.
Unplug the sound chip.
Remove the sound chip.
De-solder the pins of the port from the board
See this guide on how to use a soldering iron.
Remove the port from the board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
