Einleitung
The trackpad is used to track mouse movements based on finger movements on the pad. This can get damaged easily due to liquid damage, overuse, or dropping the device.
Was du brauchst
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
