Einleitung
In this guide you will learn how to remove and replace your Asus Vivobook X540SA-BPD0602V's Disk Drive. If your disk drive breaks you wont be able to put in any CD's or DVD's, and sometimes needed software updates come in a disc format.
Was du brauchst
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
Remove the two battery screws (15.6 mm)
Two top corner screws (12.5 mm)
Six case screws (9.7mm)
Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
The Disk Drive is located within the upper right hand corner of the laptop.
Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
I have a Asus X540U can I replace the ODD with a HDD SSD Caddy?
