Zum Hauptinhalt wechseln
Asus VivoBook X540SA-BPD0602V Keyboard Replacement
Was du brauchst
  1. Asus VivoBook X540SA-BPD0602V Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G111, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 40
Insgesamt: 2,636
